1 members (Ponchogl),
133
3
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2020 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 69 | I had the same problem in my '47. It has a 235 from a '57 Bel Air, but is using the flywheel and clutch from a '54 passenger car. The part number from your clutch should be stamped on the face (mine is 3835216) and you can look it up at http://www.gmpartswiki.com/query to find what model year and size you need. Hope this helps!
Mason
1947 Chevy 3100 -57 Chevy 235 -95 S10 T5 Transmission -97 Blazer 3.42 Rear End
