Hello Stovebolters. Im doing a gear swap on my 12 bolt truck rear-end. The rear came with stock 4.11 gears and im installing 3.73 gears. I've set the pinion depth with a flat piece of metal stock and dial calipers to what it is calling for witch is 2.824". Im having trouble reading the gear pattern can anyone help translate what I have here. Thank you.
