Originally posted by Fahr:
is it worth the trouble to go to a dual master
I don't think it will be hard to find people who will take either side of that question! I'd want to know what you intend to use the truck for... If you wanted a parade-use only type restoration I'd be in favor of leaving it original. If you plan to build a long-haul cruser my bias would be to upgrade the entire brake system.
