| | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A 1940 flywheel is held on by 3/8” bolts and has a slightly larger center hole. 1942 on up used 7/16” bolts. I have seen 1940-41 flywheels drilled for 7/16” bolts, and the center hole diameter was not an issue, (even though it was designed to center the flywheel I am sure), as the three lineup dowels keep the flywheel in position.
Bellhousing and transmission are no problem.
See the USA in your vintage Chevrolet! My Blog | | |
