Thanks to everyone for their feedback. I do have the rebuild kit for the hinges so I will try that. Although I dont notice much play in them. The belt line will come up if a hold it up slightly and I was assuming when I put in the door latch that would help. I wish I could move the door forward but I am at the limit on the top hinge with the extra opening of slots I put in. I did not do anything to the lower hinge in the way of extending the slots and maybe that holds the top one from going all the way forward? And like the other comment maybe if I cant get it any better leave as is. It closes perfectly right now but for sure the rear door gap is tight and the front loose.
