When I installed a bigger headlight assembly on my Harley, I used a small bright blue LED in the chrome housing as a high beam indicator. They're available on Ebay in all sorts of variations and they're dirt cheap. They also work on 6 Volts at full brightness, if you're still running the original electrical system.
