| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I know up to 1938 the high beam indicator was an accessory that clamped to the bottom lip of the dash. I'm not sure when they put the high beam indicator in the speedometer housing. If you don't have a socket in your 39 it likely was under the dash as well. If you can even find one hold on to your wallet. If you're not concerned about being "correct" you can do whatever you wish. Hang a small light under the dash or drill a hole in the dash & put al light there. Tie it into your high beam circuit. Whatever trips your trigger.
