| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | On the 216 pump that I converted to a bolt-on 2-groove pulley by machining the belt groove off the pressed-on pulley into a mounting flange, I used a pulley for a 302 Ford V8. It was necessary to re-drill the fan mounting holes to the proper bolt circle, but the pulley hub has plenty of room to do that. Jerry
