10 members (oldsteve, Mr Bailey, cmayna, 216wny, baldeagle, frogfarmer, JW51, Peggy M, tclederman, 1 invisible),
35
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,005 Posts1,055,261 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | I have a big block Chevy drivetrain installed in my 46 Chev 1/2 ton with a Chev Nova rear end. Problem is the universal joint bearings on the big block driveshaft is too large by about an eighth of an inch and therefore won't fit onto the Nova rear end. My question is can you take the universal joint ends apart and install smaller diameter bearings to fit the rear end or do I have to weld onto the driveshaft a complete rear yoke and universal joint. The driveshaft has to be cut and balanced so I was thinking the latter. Any info would be greatly appreciated. Bob T | | |
