| | | Forums66 Topics128,048 Posts1,055,664 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,031 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,031 | You could theoretically make cab corners from flat metal, but it would be a lot of work. The roof corners would at least get you a good start on the profile. I just eyeballed the top and bottom of my cab and the contours don't look that different. Can't hurt to try. Let us know how it turns out for you.
