I'm surprised Jim Carter has 3600 Huck drums. Maybe that bodes well for 3800 Huck drums somewhere down the line. At some point I'll probably have to do the 14-bolt swap when my drums wear out. The front ones are worn thin but now there is an aftermarket disc setup available. Just in time.
1951 3800 1-ton
"Earning its keep from the get-go"
In the DITY Gallery
1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
