0 members (),
160
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | That is correct Block the other side Chalk mark both axle and wheel And you will get 2x the normal turns on one wheel with the other blocked
Example I block one wheel on my truck Make 10 turns on the wheel and see about 25.5 turns of the input shaft 10/2 = 5 turns of both wheel if I was on the road 25.5/5 = 5.1 so that’s a 5.13 according to the books -s | | |
