found this sway bar for 5'5-59 trucks, wondering if it would fit on my '46 1/2 ton.
If you have one its about the dimension between the link eye holes matching the 46 frame width.
It mounts backwards to normal, ie: onto the I-beam eliminating the need for adding a crossmember.
I love that the design is so outside the norm. photo attached
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
