| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,846 | As I mentioned earlier, a well-tuned 355 cubic inch small block Chevy will turn 6200 RPM with a "350 CFM" Holley 2 barrel. It just won't do it at the manifold vacuum where the flow rate of the carb is measured. Jerry
