| | | Forums66 Topics128,214 Posts1,057,488 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 5 New Guy | | New Guy Joined: Dec 2020 Posts: 5 | I have a 1941 Master Deluxe (yes I know it is a car but after looking at other forums I am going to where the best place to go for advice on these motors is). Question #1: I and my sons are putting it back together. After installing a new water pump I installed a new thermostat. Not sure if I put the right end up. I placed the spring down and bolted it back together. Then I thought well that does not seem right.
Question #2: We have run the motor but not for more than 20 minutes at idle. The heater hose is looped back to the pump, the heater core leaks. It got up to temp and never overheated. The top and bottom hoses where warm. We did discover that unlike a modern car with an overflow tank on this it is good to fill the radiator to the top, the overflow tube works. So with an unpressurized system like this how high should the radiator be filled? What is the proper way to get any air out of the system on this car? I am used to wait for the air to stop coming out the top but is this the same method for this one?
1941 Chevrolet Master Deluxe with original 216 1987 Chevrolet Monte Carlo
Entire Thread
1941 216, Thermostat question, may have made a rookie mistake
| TKruger | 12/16/2020 8:35 PM |
Re: 1941 216, Thermostat question, may have made a rookie mistake
| Wrenchbender Ret. | 12/16/2020 9:38 PM |
| harv | 12/17/2020 1:45 AM |
| Phak1 | 12/17/2020 2:12 AM |
| Tiny | 12/17/2020 12:57 PM |
| TKruger | 12/17/2020 3:22 PM |
| Tiny | 12/19/2020 3:56 PM |
| Hotrod Lincoln | 12/19/2020 4:26 PM | |
