| | | Forums66 Topics128,051 Posts1,055,764 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2019 Posts: 119 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 119 | I recommend that you use a strap wrench to tighten the packing collar.
The strap wrench applies uniform pressure to the collar so you can really tighten it. If you use a pipe wrench or a large pair of adjustable pliers (Channelocks) you are applying pressure at 2 points on the collar. That distortion makes it hard to turn the collar but it really is not tight on the packing.
Rusty
