| | | Forums66 Topics128,012 Posts1,055,321 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 223 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 223 | I had a little buckle on one side above the DS door next to the center bow. I got creative and used some aluminum flashing that I slid under the center bow and ran it down both sides. I tucked it under the door molding on each side. Used just enough to cover the buckle. Problem solved. With a black interior I feel it adds a little bling...almost a perfect match to the dash panels and gauge bezels. If anyone tries this, you will have to split, cut, the flashing in the middle or the geometry of the roof won't let the flashing lay flat...I know trust me on this one. I rounded the back edges of the flashing in the center to give it a somewhat finished look. The two pieces fit against each other. I then used 3M double sided Scotch tape to hold the flashing to my headliner. | | |
