If you don’t mind not having original ,you may be able to get a aftermarket valve that will work .The trick would be to find one that worked with the original knob in the inside ,if I remember right the control on the inside is a turn knob instead of a push pull.Someone has used theses before look through some posts to see maybe someone posted the valve they used
