This one works well and is the same seller I bought mine from (circa 2017): https://tinyurl.com/y5vrx8u3
It has the right brackets, however one must be bent slightly if your truck is like mine (not a difficult job at all). The hub on this one (the part the inside linkage arms connect to) is made so that it is adjustable in two places...even though as I recall the instructions you get only mentions one adjustment. Good luck.
~ Jon
