| | | Forums66 Topics128,187 Posts1,057,316 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | It's also possible the timing gear has jumped a few teeth and the spark is so far out of time it won't run, but even then, there should be some fire at the plugs. You'll need to remove the valve cover and watch the valve action and the timing ball and pointer to see if the distributor and the crankshaft are in the proper phase with each other. Jerry
Entire Thread
spark at the coil, but not at the spark-plug wire
| Ol' Red | 10/17/2020 1:17 AM |
Re: spark at the coil, but not at the spark-plug wire
| klhansen | 10/17/2020 1:30 AM |
| Hotrod Lincoln | 10/17/2020 1:36 AM |
| Ol' Red | 10/17/2020 1:42 AM |
| Ol' Red | 10/17/2020 1:37 AM |
| klhansen | 10/17/2020 4:16 AM |
| Wrenchbender Ret. | 10/17/2020 3:44 PM |
| Ol' Red | 10/17/2020 8:37 PM |
| Hotrod Lincoln | 10/17/2020 11:11 PM |
| Ol' Red | 10/17/2020 11:28 PM |
| Hotrod Lincoln | 10/17/2020 11:40 PM |
| Ol' Red | 10/17/2020 11:48 PM |
| Hotrod Lincoln | 10/17/2020 11:55 PM |
| Ol' Red | 10/19/2020 12:43 AM |
| klhansen | 10/19/2020 12:55 AM |
| Phak1 | 10/19/2020 1:22 AM |
| Ol' Red | 10/19/2020 1:37 AM | |
