11 members (MickeyP, FAST55, LAROKE, Jon G, lumbersawyer, EchoBravoSierra, 55shaker, Joe H, 3B, 68ironhead, VEW),
50
Mod | | | Forums66 Topics128,175 Posts1,057,118 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2019 Posts: 119 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 119 | The primary variable left is to determine if the float is at the lowest limit of travel when it is installed in the tank and the resistance at the position.
What resistance does the sending unit read when it it installed in the tank and the tank is empty?
What does the gauge read when you have the sending unit out of the tank and you let the float drop as far as it can go?
I agree with the suggestion to look at the position of the wiper on the coil.
Rusty
