0 members (),
145
Mod | | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | Dieseling is usually caused by a too-lean idle mixture and too high an idle speed. Go a little richer on the idle mixture screw (counterclockwise), and turn the speed down so you can almost count the fan blades as they turn. Unless you've got a radical camshaft and/or a vacuum leak, the engine should idle down to less than 500 RPM. Jerry
