| | | Forums66 Topics128,089 Posts1,056,116 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | That's an odd one there. It's not rhythmic, which you would expect if it were some sort of valve train or piston problem. The motor sounds good. I think the first thing I would do is take the valve cover off and see if there's anything loose under there. It could be something metallic just bouncing around in there. It sounds very light, like a small piece of metal. | | |
