Any pictures?
Is the truck running, brake lines in place?
Is it a 1953 HOUSING with a 3.90 insert?
Are the parking brake lines connected?
If it is a Task Force HOUSING and you have Task Force Wheel Cylinders, those 1952 pre bent lines won't work. IF it's a truck with the TF axles and housing in place no brake lines fitted, the PO COULD have reversed the wheel cylinders.
More information and pictures needed.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
