| | | Forums66 Topics128,036 Posts1,055,454 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | If you have the "crash box" 4 speed with the reverse lockout lever on the shifter, those transmissions are pretty flimsy, and are subject to wear. Chances are the shift rails in the top cover are the problem. I'd suggest removing the cover and disassembling the shift rods, looking for wear and/or broken parts such as springs and detent balls. It's also possible for the bearings and shift collars in the main gear set to get worn and hang up while they are being moved in and out of mesh. That box has no synchronizers to give trouble, which can be a good thing! Jerry
