1 members (crenwelge),
100
2
Mod | | | Forums66 Topics128,281 Posts1,058,466 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 3,500 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,500 | An old racer trick is to fab up some plates that clamp the leafs together in front of the axle. These are about 3/4" wide and are an 1" or so longer than the width of the leafs. Drill holes in the plates that will allow them to be bolted on top and bottom of the springs. 5/16" or 1/4" grade 5 bolts with locking nuts should work. These plates are mounted where each leaf meets, leaving about 3" or so between the end of the leaf. This only needs to be done in front of the axle, and will really tighten up spring pack and act as a traction bar. I have used these on my 56' 210 for years and along with traction bars it realy hooks up, and it's cheap!
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | |
