Yep, it's pressed in.
Mine came out with some vice grip twisting... oily spot, good chance it's not rusty.
If you're worried maybe tap a screw into it and use something to slide hammer.
FYI: it's easily replaceable with 3/8 steel tube if you can figure out the correct length.
