| | | Forums66 Topics128,026 Posts1,055,410 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | For the most part switches don't care about voltage. They care about amperage so you're correct with that assumption. If the wattage is the same, a 12v circuit will draw half the amps of a 6v. If the 12v headlights are rated a higher wattage it may make a difference but it would have to be a lot higher I would think. If I'm wrong someone will point it out.
