| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2017 Posts: 45 'Bolter | | 'Bolter Joined: Jul 2017 Posts: 45 | Hey guys, Need some advice. There's a lot of junk and a lot of surface rust on the inside of the doors on my series II, 1955, 3100. 65 years worth. I was thinking of cutting an opening in the interior panel to gain access. Mindful of the mechanisms inside. Clean it out. Clear the drain holes. Rust protection and some sound deadening material. I can't find anything that tells me somebody has already done this and how they did it. I'm mostly concerned with how to put the cutout back in and have it look acceptable. Don't want to spend 3-4 hundred bucks for a door panel cover up. Any suggestions? Also considering leaving it alone. It probably won't be any worse for the next 65 years. Appreciate any thoughts on this. Jim
Jim
1955 Chevy series 2 6 cylinder, 3 on the tree Short bed, step side
