| | | Forums66 Topics128,078 Posts1,056,057 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Look at the motor mounts. The 292 is the only engine with them offset side to side. The 194, 230, and 250 have mounts directly across from each other, and the same distance from the bellhousing as a V8. The passenger's side mount on a 292 is about 3 inches further forward than the driver's side mount. The HEI distributor with the large diaqmeter housing and cap will fit the earliuer engines with point-type distributors. Jerry
