Truckstell made a similar setup for Ford- - - -as far back as the 1920's. I had a friend with a Model TT fire truck with a Truckstell system, but I believe it was an "underdrive" that allowed the driver to select a very low ratio starting gear to get the rig moving. Since the T model only had two speeds, the ability to gear down in both first and direct drive allowed coach builders to exceed the designed gross weight for commercial vehicles.
