You can cut a hole in the bottom, it's just pressed paper, reach up from back side and remove two screws that hold the striker on. Then you can carry the whole glove box door to a GOOD locksmith or remove the one screw that retains the latch mount sleeve and remove it. I can't remember if the latch will remove through the hole in the door if locked but a cut off wheel will remedy that---it's no good anyway.
Evan
