You didn,t say what year truck it is in but if you really want to get it right you need to pull the pan. You may have pulled part of the pan gasket out when you removed the cover. If you don,t be shure to get some RTV in the edge of the pan. Did you put in new gaskets & damper & not replace the seal?
