8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible),
57
Mod | | | Forums66 Topics128,075 Posts1,055,919 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | The last time I installed a rope seal, I made a tool from an old 4" diameter piston machined down to 3 7/8" which is the size of the seal surface on a stovebolt crankshaft, and used it to roll and pack the seal rope into place. I believe there is a picture of me using the tool in John's article on the buildup of his 261 engine. I used a piece of broomstick through the wrist pin hole as a handle for the packing tool. Roll the seal firmly into the block and the bearing cap and shape it to the exact radius of the crankshaft. Use some oil or assembly lubricant on the crankshaft- - - -a dry seal creates a great deal of drag.
Wrap a piece of thick leather around the crankshaft snout to keep from scarring it, and use a large pair of pliers or a pipe wrench to help turn the crankshaft. The seal will increase the turning torque a considerable amount. Jerry
