Use a hole saw if you want a smooth arc. Drill a 1/4" hole in a piece of round stock, clamp it to the frame flange where you want the cutout, and use an appropriate-sized hole saw to make the cut. Smooth it out with a die grinder. Reinforce the frame around the cutout with a piece of plate welded or bolted inside the C-channel.
