| | | Forums66 Topics128,268 Posts1,058,375 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | If you still have the stock rear springs you can remove 2 or 3 leaves, (like maybe 1,2, and 4 counting from the axle up), that will bring it down about 2" from stock. If you need more drop than that you can take the modified springs to a spring shop and for less than $100 get them dearched to whatever ride height you want. This will really soften up the ride. You can run air shocks if you plan on carrying much of a load. To get even a smoother ride put poly or teflon liners between the leaves. | | |
