| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | A hardwood wedge driven between the clutch cover and the bellhousing can serve as a "helper" also. Just do something to keep the hammer blows off the front of the thrust bearing. Use the water pump housing as a drill guide to spot-face a couple of dimples in the front of the block to be sure the holes get drilled in the right place. Jerry
