| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | A suggestion; it is very easy to turn one down on a lathe but LEAVE THE THICKNESS of the brake drum the original size on the axle pilot (hub). You really don't need a "floating" brake drum that is only positioned by often not too tight fitting (to the brake drum) wheel lug bolts.
Evan
