I used the pedal assy, and booster/mc from an '86 C10 in my 48. I used a column from a late '80's van. should be the same as the truck column, only shorter. Keep in mine that I haven't driven my truck yet, but I am happy with the way that it turned out. I was not able to use the factory bracket from the van (wrong angle). I had to by an aftermarket column drop from ididit (about $75), and weld a flat piece of metal across the bracket just below the bottom of the dash. I have a Camaro clip in my truck.
