After speaking with a local machinest, it sounds like the axle bores will need to be opened up and sleeved before fixing the kingpins and it will take some time. So I will plan to steal the 2 ton axle and have it repaired and rebuilt. (It has about ¾" of slop) and if timing works out, maybe Randy's disc brake kit will arrive about the time the axle is ready. Maybe
