Scuff it clean, apply EPOXY primer which will prevent any rust creep as it's the only product that's designed to stop rust. After the epoxy is on, put anything over it as it just doesn't matter because the Epoxy is THE most important first step... including Pour products...
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
