| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | You've got the right equipment to do a proper test with that vac/press gauge. The most important result you're looking for is the amount of time the pressure and vacuum remain after stopping the engine. Those check valves used to be the most common failure items- - - -now the rubber parts in older pumps are failing due to "deathanol" additives to gasoline that create delamination and leaks, either into the crankcase or to the outside. A damaged diaphragm can fill the crankcase with explosive vapors, and/or dilute the oil enough to get rod and main bearing damage.
Good luck!
