1. Do you still have the original points distributor? 2. Have you ever tested a stock GM HEI to see how much clearance or interference there actually is? Maybe a friend has one just to try for fit.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn |
