1. Red to coil positive. 2. If orange is really brown, then brown to coil negative. 3. Black to firewall metal. (ground). Must be touching good clean metal spot on firewall. No paint. 4. Wire from ignition switch "ON" terminal to coil positive. Be sure wire is not coming from ignition switch battery terminal.
It sounds like you also have a wire from the battery to the coil positive. Take it off. Not used.
Where did you get the replacement pick up?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn |
