| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | We often find ourselves looking for the easy fix with bad acting doors. Me included. The truth of the matter with these doors is that you need to address all of the aspects of the door/latch/striker. Number one would be to rebuild the the door hinges. Number two would be to install the door without the door seals, with the striker removed. Number three would be to make sure that the belt line of the door lines up with the belt line of the cab. Doing those three things first will make your life much easier to tweak the door into an acceptable position to close properly.
