| | | Forums66 Topics128,052 Posts1,055,773 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | There is a tab on the sender flange that has a wire to the back cab wall. that is a very necessary ground. Be sure it's there and has good contact to metal. I assume you have a Chevy truck somewhere between 60-66.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
