1 members (Peggy M),
131
2
Mod | | | Forums66 Topics128,105 Posts1,056,538 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,105 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,105 | I second DaveMcK38's suggestion of something to pull the park brake cable out of the way. A simple extension spring hooked around the cable and possibly the leaf spring should do the trick. I don't think it would be a big deal to manhandle the clamps at the backing plate to increase the angle of the cable exit. They're just sheet metal and the cable is flexible so unless you tweak them a lot, everything should work as designed. I also agree that 2" spacers would be a bad idea.
