| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Those are pretty stiff frames. I don't see why you couldn't remove the old crossmember if you have the new one welded in place. But like you said, you need to support the motor differently it sounds like.
...Or you could leave the old crossmember in there to add stiffness to the frame.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
