7 members (MickeyP, TGP, 68ironhead, Nhluvstruck, Otto Skorzeny, treegrower, Peggy M),
56
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | It sounds like you've got a mismatch between the master cylinder and the wheel cylinders like Rod suggests. If the master cylinder diameter is too big, there will be a very short pedal stroke and not enough hydraulic advantage between the MC and the wheel cylinders. Make sure your replacement cylinder is correct for the vehicle application- - - - -some low-IQ computer jockey at the local auto parts store might have tapped in the wrong info on his keyboard! Jerry
