| | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2019 Posts: 119 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 119 | This is a follow-up to my prior post in this thread. Thanks to a PM from Rocket Man I realized that my response was misleading.
I was confusing rear leaf spring bushings in Chevy cars compared to trucks. Both use a rubber sleeved bushing in the rear suspension but in different locations.
In many of the older cars the bushing in the front eye of the rear spring is a rubber sleeved bushing. In trucks it is a metal sleeve that the pin goes through.
In some trucks the rubber sleeved bushing is used in the bracket that attaches the rear axle to the spring.
In either application the bolt that clamps the inner sleeve of the bushing should be tightened only when the suspension is loaded. The truck shop manual describes this procedure.
I apologize for the confusion I created.
Rusty
